Windows 8.1
AndyH
Windows 8.1
Was released yesterday (17 Oct) to the public.
From what I have read so far, this appears to be around a 3gb update?!
27 REPLIES 27
redsetter
Re: Windows 8.1
this is a good site/forum on operating systems.
http://forums.mydigitallife.info/
Devonian
Re: Windows 8.1
It doesn't work on either my laptop or desk top.. rubbish!
pcathomerepairs
Re: Windows 8.1
Hey Devonian
what make spec are your desktop and laptop
Devonian
Re: Windows 8.1
I have a Dell XPS 15 laptop and a HP Pavilion P6 desk top.
pcathomerepairs
Re: Windows 8.1
wow i have an xps running w8 and i would be very
surprised if the hp could not run it as well
have they both got 2 or more gig of memory.
Devonian
Re: Windows 8.1
I know, they should be fine.
It starts installing, then gets towards finishing then gives an error code:
0x80070005 - 0x4000D
Then restores to previous settings.
I haven't looked into it to much, just tried with McAafe disabled.
They both have loads of memory by the way.
HPsauce
Re: Windows 8.1
Indeed, I've got an old HP Pavilion with a Pentium-D processor and that's happily running 8.1.
Devonian
Re: Windows 8.1
pcathomerepairs
Re: Windows 8.1
0x80070005 - 0x4000D this is the problem MS have pulled the update for
may just need a new disk when they have fixed the problem
Devonian
Re: Windows 8.1
How do you mean need a new disk mate?
I don't have an old disk!  Grin
pcathomerepairs
Re: Windows 8.1
i just assumed lol hold off and download the fixed version Lips_are_sealed
Devonian
Re: Windows 8.1
Grin
Good advice.
ReedRichards
Seasoned Pro
Fixes: 25
Re: Windows 8.1
Quote from: 365webhost247
I think that's wrong.  As far as I can ascertain, Microsoft pulled the update for Windows RT 8.1 because it can result in a Blue Screen of Death http://kickthatcomputer.wordpress.com/2013/10/19/windows-rt-8-1-upgrade-fails-with-boot-configuratio... .  To quote Wikipedia:
Windows RT is a variant of the Windows 8 operating system designed for mobile devices which use ARM architecture.
So that particular BSOD issue won't affect either of Devonian's computers.
ReedRichards
Seasoned Pro
Fixes: 25
Re: Windows 8.1
It seems Devonian's problem might arise if he changed his user profile since installing Windows 8.0
