Windows 8.1 questions...
- Windows 8.1 questions...
- « Previous
- 1
- 2
- Next »
Re: Windows 8.1 questions...
06-05-2015 8:06 AM
06-05-2015 8:32 AM
Not true
Quote Unless you're installing a corporate version there is no such thing as separate accounts for admins....
06-05-2015 8:35 AM
Easy enough to add other non-admin accounts of course, but not how it starts off.
Of course the other "catch" is that it will also try to make you use a Microsoft account for logon, again something trivially bypassed but deliberately obscured by Microsoft.
06-05-2015 9:43 AM
@vfd
Linux is just as riddled with problems but people spend less time exploiting them as there are less returns on their time, for every Linux system there are a million windows systems, its like economics 101, you don't waste your time on the small fry when you have the big markets to go after ....
using separate accounts was a good thing In earlier versions of windows but in the newer versions (7 onwards) is just an unnecessary pain in the backside, half the programs will require elevation to run which means every time you wish to run them you will need to log in as the admin (particularly true for games and editing software) much better to simply run the admin account and utilise UAC at the top level (some people cry about the popups but hey ho) to remain secure but functional without the hassles of trying to operate in the nt4.0 era
also multiple accounts increases the security risk on a single user system,
06-05-2015 10:07 AM
Totally wrong, please provide a reference to support that assertion.
Quote from: nanotm you need to use a Microsoft account on w8.1 for you to be able to get all the updates
06-05-2015 10:19 AM
06-05-2015 11:20 AM
Quote from: nanotm the windows store doesn't work without a Microsoft account....
You don't need the Windows store for updates. Many of us use Windows 8.1 as a 'pure' desktop (marginally improved Windows 7) and almost never go near the Metro/Modern/Store.
06-05-2015 12:13 PM
I just would quite like separate accounts,
one for normal use and one for installation/updates of applications.
I would be happy to settle for one account - provided it can temporarily gain admin rights.
I doubt there will be any interest in buying stuff from Microsoft, so the password thing isn't needed.
06-05-2015 12:39 PM
Quote from: vilefoxdemonofdoom This is going a bit off-topic.
That is exactly how it works. You can have an admin account for updates and a user account for regular use. The admin account will not normally run using the full admin rights, so you need to respond to a prompt when doing actions such as installation.
Quote from: vilefoxdemonofdoom I doubt there will be any interest in buying stuff from Microsoft, so the password thing isn't needed.
Depending on the sensitivity of things on your computer, you might want passwords for other reasons such as hackers. If you use local machine accounts for computer login there is no need to password protect them if you don't wish to. If you use Microsoft accounts for computer login, then I think that Microsoft do require you to have a password.
06-05-2015 6:43 PM
- « Previous
- 1
- 2
- Next »
