Windows 8.1 (again)
- Windows 8.1 (again)
Windows 8.1 (again)
02-10-2013 4:18 PM
Advice needed please for an elderly novice.
If/when I download the upcoming Win 8.1, can someone tell me whether it would enable a straightforward transfer of all currently loaded programs etc. in
win/8, or shall I have the same problems as recently, when win 8 on my fairly new laptop blew up completely and I had to do a complete reset to ex-factory
condition.
condition.
5 REPLIES 5
Re: Windows 8.1 (again)
02-10-2013 4:42 PM
Hi
Its an in place upgrade. You will not lose any data or settings
Tony
Tony
02-10-2013 8:40 PM
Thanks very much, that's an enormous relief
17-10-2013 11:41 PM
You could probably fly to Redmond faster than compete the upgrade but it's should be fairly straight forward and all remains intact.
podman
podman
18-10-2013 8:49 AM
*Solved* - it was the Steel Series mouse/keyboard software that was the issue, once uninstalled Windows 8.1 update worked!
18-10-2013 9:55 AM
With my fantastic connection my update took about six hours to download !
The only potential problem which was not immediately obvious was that it had uninstalled the AV I was using (Avast) and had not activated Win Defender. Still, that was easily sorted once it was noticed. What won't be quite so easy is resetting all the minor adjustments I had made during the previous months as I can't really recall how I got where I was
