Windows 8.1 Update Problem
artmo
Aspiring Champion
I have discovered that my laptop is not updating. I was hoping that a system restore might sort it for me. Where is system restore on W8.1?
Any advice please in simple terms - not too PC literate  Wink
15 REPLIES 15
Oldjim
Resting Legend
Fixes: 63
Re: Windows 8.1 Update Problem
HPsauce
Control Panel, Recovery but it may not be the right answer to the problem....
artmo
Aspiring Champion
Thanks Jim and HPSauce.  I'll have a go at it this afternoon.
I was waiting for the 'big' update to 8.1 from MS but reports here in the US say we will be disappointed as it is only changing some minor issues. So far I'm not pleased with it.
HPsauce
While our W8 PC (mainly used by SWMBO) does now have 8.1 it didn't change much.
However it also has Classic Shell on it so any changes are largely irrelevant to normal use.
Microsoft I think have a "Fixit" for Windows Update issues.
Edit: Troubleshooter here: http://windows.microsoft.com/en-gb/windows/troubleshoot-problems-installing-updates#1TC=windows-8
ReedRichards
Seasoned Pro
Fixes: 25
You will find you can turn off the computer more easily with Windows 8.1 (assuming you have not installed a Start Button replacement like Classic Shell).
artmo
Aspiring Champion
I've got my problem solved and I have the update function working again. Thanks again to Jim and HPSauce Smiley
artmo
Aspiring Champion
This week got my first automatic update since sorting out my problem. Everything worked fine Smiley
ReedRichards
Seasoned Pro
Fixes: 25
You should find 'Windows 8.1 Update 1' is now available as a very large download.  It makes 8.1 a bit more friendly for conventional computer users.
artmo
Aspiring Champion
Thanks for the info. Is the update the one showing as: Windows 8.1 Update for x64-based systems (KB2919353) ?
It's the only one I can see at present waiting to be installed.
Mal08
Art,
The big one is:
KB2919355
http://support.microsoft.com/kb/2919355
artmo
Aspiring Champion
Thanks Mal. When I checked again that was the one waiting to be downloaded - I must have typed the wrong number Embarrassed
I've now updated. I can see a few minor changes but nothing major. Is there a list somewhere of the changes?
Mal08
The official bit:
http://windows.microsoft.com/en-us/windows-8/whats-new
http://www.cnet.com/uk/news/windows-8-1-update-might-change-your-mind-about-windows-8/
OR
or let google be your friend !!!!!
https://www.google.co.uk/search?q=whats+new+windos+8.1+update
Not a great deal of difference - apparently there will be quite a bit more later in the year !!!. Talk about back peddling - !!!!!!!!
artmo
Aspiring Champion
Thanks again Mal. I have to say i was expecting more from the update. it seems only minor cosmetic.
ReedRichards
Seasoned Pro
Fixes: 25
I like this change:
our mouse works more consistently anywhere in Windows. Move your mouse to the top of the screen to see Close and Minimize buttons in any app. Move your mouse down to the bottom of the screen to see the taskbar from anywhere in Windows.
But there is some way to go yet for non-tablet users.
