Windows 7 won't give me my USBs back
- Windows 7 won't give me my USBs back
06-05-2014 10:29 AM
I downloaded 'USB Safely Remove' but it tells me it can't stop the USB and says it's in use by AVG and System files do I want to manually stop them but stopping the system files may have harmful effects.
Any idea what these system files are? are they windows or are they system files that belong to the USB and would reformatting the USB help?
Re: Windows 7 won't give me my USBs back
06-05-2014 10:33 AM
06-05-2014 10:40 AM
06-05-2014 12:21 PM
06-05-2014 12:41 PM
Can you please provide a link ?
06-05-2014 10:42 PM
Quote from: TORPC How is poor Windows 7 getting the blame ?
The clue is in the title of this thread. Well more of a dead give-away than a clue, actually.
06-05-2014 11:11 PM
07-05-2014 8:07 AM
As I said in the text of the post 'Safely Remove USB' also tells me system files are holding the usb back too hence my question if anyone could tell me if they relate to Windows or the usb itself.
I have tried stopping AVG but the usb still won't release.
The only way I can get it back, in my eyes safely, is to reboot.
07-05-2014 1:25 PM
You will need to look in taskmanager
Click on Start (Type in without the quotes) "taskmgr.exe"
Right click on the taskmgr.exe icon then choose run as administrator
When task manager opens up look in the processes tab, you may have to click on (Show Processes From All Users)
You might have something called mobsync.exe Microsoft Sync Centre (right click on it & choose (End Process Tree)
Or
Their could be similar worded / phrased entry by a 3rd party program like AVG
07-05-2014 6:11 PM
07-05-2014 7:49 PM
Forum Moderator and Customer
08-05-2014 12:02 AM
An Operating System that doesn't operate?
08-05-2014 7:25 AM
08-05-2014 8:14 AM
Which is why I asked on here about the system files USB Safely Remove mentions! Anyone any idea where they are from?
My irritation is I use 2 different PCs one is mine the other a Charities and I need to switch USBs for printing, as I don't want their printer and photocopier drivers on my PC [plus it's a pain unplugging the cables back and forth], so having to shut down is a pain.
As it doesn't will all my USBs would reformatting them help?
08-05-2014 1:55 PM
