Windows 7 will not go to sleep
- Re: Windows 7 will not go to sleep
03-03-2015 9:00 AM
I have checked the power options in the control panel and yet the PC will not sleep after the preset times. Any ideas what the problem is?
2 REPLIES 2
03-03-2015 9:12 AM
There are quite a few programs around that prevent sleep. You can try using something like Task Manager or Process Hacker to kill one at a time to find the offending one; rather a slow and boring process sadly. If you have just installed something new and the problem started that is probably the reason.
I recently had this with a program called Air Parrot; I was able to pin it down fairly quickly because it was a recent install.
I don't know of any quick way to find out what has rejected a Sleep request: maybe there will be an indication in the Windows lots.
03-03-2015 9:19 PM
Go to an admin command prompt and type
That would be my starting point.
Anything not appearing in there is going to be harder to track down.
Quote powercfg /requests
