Windows 7 weekly update
- Windows 7 weekly update
13-02-2015 3:09 PM
Here we are 12 hours later, and the message hasn't moved on, not even to update 2 of 2.
Cntl/Alt/Del doesn't do anything.
What should I do?
Thanks for any help
Re: Windows 7 weekly update
13-02-2015 4:11 PM
13-02-2015 5:03 PM
York.
13-02-2015 5:26 PM
The last one today was a .NET update 4.5.2 and it seemed to stick for about 5 minutes with no sign of progress and then suddenly it announced completion so I'm about to reboot.
Edit: Success.
Hope you get sorted penneck
13-02-2015 6:20 PM
but the way it is worded... it seems to mean... "don`t switch off until I have finished, otherwise i`ll blow up the machine, and you will have to buy another one! "....
13-02-2015 7:20 PM
York.
13-02-2015 8:24 PM
13-02-2015 8:35 PM
I closed the lid. Today it was still doing the updates
Anyway it updated within 5 minutes from opening the laptop this morning - it was still on and hadn't shut down, but obviously did after completing the updates this morning.
NE
14-02-2015 1:27 PM
After I posted the query, we had to go out to babysit our grandchildren. When we got back late last night, my wife found her laptop had switched off. She turned it on, and it was okay. She didn't tell me what had happened. I was unable to have another go at dealing with the problem until just now, and found her laptop powered off. I thought she had been fiddling with it and had managed to turn it off. That is when I found out what she had known since last night.
Whether there was a problem downloading the updates from Microsoft during those 12 hours, or not, I cannot tell.
Anyway, all's well that ends well.
Thanks to you all for your help. I'm grateful
14-02-2015 2:10 PM
By default they seem to be set to sleep or hibernate at the slightest hint of user inactivity, whether plugged in or on battery.
I've seen systems that have had no updates applied for 18 months or more as a result!
Now that may be fine for "road warriors" managed and monitored by a corporate support department, but for the average home user where the laptop is used very much like a desktop, it's rubbish.
I suggest going through all the power settings and change them more to desktop settings, especially what the power button does and what closing the lid does too.
Essentially you should minimise the sleep/hibernation activity UNLESS running on battery and you really need it, otherwise power off normally when not needed.
A "proper" power off will, by default, apply any outstanding updates before shutting down.
14-02-2015 10:45 PM
