Windows 7 virtual drive software?
Fixes: 92
Can anyone recommend any? Doesn't seem like Daemon Tools is supported yet...
MuppetGrinder
Re: Windows 7 virtual drive software?
if I find one I'll let you know
MuppetGrinder
Hmm, this is proving tougher than I though Undecided.  I did get a program called Virtual Drive Creator to work, but it's not realy anything like Demon, it takes a folder and turns it into a disk (not sure what the point is to this but meh).  A word of warning though, if you decide to try it, turn off System Restore, it seems that it causes some confusion with that process and the system hangs there after.  Still looking for a progie to mount images though.
Fixes: 92
It's not free, but UltraISO seems to work.
MuppetGrinder
I've got an interesting little sceniro now.  After trying out a couple of apps, including some older versions of Demon, all unsucssful, I now have 2 virtual Bluray drives and no interface program for them Crazy  The thing is they didn't show up untill after I had uninstalled all the apps, and windows auto reset for an update....maybe that's got somthing to do with it hmm?  Still, makes the My computer screen look like I can afford an expensive rig  Grin
