Windows 7 virtual drive software?
- Windows 7 virtual drive software?
16-01-2009 9:07 PM
Can anyone recommend any? Doesn't seem like Daemon Tools is supported yet...
4 REPLIES 4
Re: Windows 7 virtual drive software?
16-01-2009 11:01 PM
if I find one I'll let you know
17-01-2009 12:26 AM
Hmm, this is proving tougher than I though :-\. I did get a program called Virtual Drive Creator to work, but it's not realy anything like Demon, it takes a folder and turns it into a disk (not sure what the point is to this but meh). A word of warning though, if you decide to try it, turn off System Restore, it seems that it causes some confusion with that process and the system hangs there after. Still looking for a progie to mount images though.
18-01-2009 1:09 PM
It's not free, but UltraISO seems to work.
19-01-2009 12:49 AM
I've got an interesting little sceniro now. After trying out a couple of apps, including some older versions of Demon, all unsucssful, I now have 2 virtual Bluray drives and no interface program for them The thing is they didn't show up untill after I had uninstalled all the apps, and windows auto reset for an update....maybe that's got somthing to do with it hmm? Still, makes the My computer screen look like I can afford an expensive rig
