Windows 7 screen shots?
- Windows 7 screen shots?
- « Previous
- 1
- 2
- Next »
Re: Windows 7 screen shots?
03-10-2011 7:28 PM
Thanks O Jim, I found it OK but it was not listed with other bits on the Start Panel. looks good but somewhat adaptable.
Strat. Just the same for me, Download greyed out but "Download anyway" leads to the message that you got! How Jeremy dodged that hurdle it is difficult to say!!
It sounds like "Work in progress" Watch for the next update.
03-10-2011 7:48 PM
Quote from: HPsauce
Quote from: jelv Where's the option to select whether you want the mouse pointer included in the screen shot?
very clever.
I gather that means it doesn't have that option - I'll stick to using IrfanView which does (see screen shot attached for the IrfanView options).
07-10-2011 9:47 AM
Quote from: jelv
Quote from: Bob I use this Firefox extension.
Have you got the save options to work recently? I'm finding they don't come up with the save dialog.
Yep, I have it working in 7.0.1 too.
07-10-2011 9:50 AM
Could you give Save, Window a try please.
07-10-2011 9:58 AM
Quote from: jelv I gather that means it doesn't have that option
Well, it's mouse-driven so a bit meaningless as the mouse is not in the captured window by definition as it's used to outline it.
Haven't found out if you can drive it from the keyboard, on my setup that's not possible but there may be some options to allow it.
- « Previous
- 1
- 2
- Next »
