Windows 7 screen shots?
I really miss the option of taking screenshots of displays which is available in Unbuntu et al.  Is there a similar add-on, plug-in or other program that can be used in Win 7 and FF 7 for the same purpose ?
  Huh Huh
Fixes: 10
Re: Windows 7 screen shots?
http://www.irfanview.net/
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Print Screen key saves what you are looking at in clipboard, then paste that in MS paint or any paint package.
Unvalued customer since 2001 funding cheap internet for others / DSL/Fibre house move 24 month regrade from 8th May 2017
Fixes: 103
I use this Firefox extension.
Fixes: 62
Use the built in snipping tool
http://en.wikipedia.org/wiki/Snipping_Tool
Thanks Bob,
I did look at FF extensions but did not see that one in the list. Will download tomorrow...SWMBO calls!!!
Quote from: Oldjim
Agreed, it does exactly what you're looking for CT. Very handy.  Wink
(and no need to download anything at all, it's there already!)
Fixes: 10
Quote from: Bob
Have you got the save options to work recently? I'm finding they don't come up with the save dialog.
Fixes: 10
Quote from: Oldjim
Where's the option to select whether you want the mouse pointer included in the screen shot?
Quote from: jelv
Grin very clever. Roll eyes
Fixes: 174
Quote from: Bob
Not available for Firefox 7.0.1
Angry
Customer and Forum Moderator. Windows 10 Firefox 64.0 (64-bit)
VileReynard
All Star
Fixes: 11
I have Screengrab working on FF 7.0.1.
Fixes: 174
Well it refuses to install citing my version of FF.
Presumably you installed it on a previous version.
pierre_pierre
and my basic Win 7 aint not got the snipping tool
Included with Windows Vista, Windows 7 (Home Premium, Professional, and Ultimate editions only)[1]
VileReynard
All Star
Fixes: 11
Quote from: Strat
I accidentally got onto the beta FF channel - so I reloaded a 3.6 version before going back to 7.0.1
