Windows 7 screen shots?
colintivy
I really miss the option of taking screenshots of displays which is available in Unbuntu et al.  Is there a similar add-on, plug-in or other program that can be used in Win 7 and FF 7 for the same purpose ?
  Huh Huh
19 REPLIES 19
jelv
Fixes: 10
Re: Windows 7 screen shots?
http://www.irfanview.net/
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Gus
Print Screen key saves what you are looking at in clipboard, then paste that in MS paint or any paint package.
FTTP 500 regrade from Tues 28th November
bobpullen
Fixes: 316
I use this Firefox extension.
Oldjim
Resting Legend
Fixes: 63
Use the built in snipping tool
http://en.wikipedia.org/wiki/Snipping_Tool
colintivy
Thanks Bob,
I did look at FF extensions but did not see that one in the list. Will download tomorrow...SWMBO calls!!!
HPsauce
Quote from: Oldjim
Agreed, it does exactly what you're looking for CT. Very handy.  Wink
(and no need to download anything at all, it's there already!)
jelv
Fixes: 10
Quote from: Bob
Have you got the save options to work recently? I'm finding they don't come up with the save dialog.
jelv
Fixes: 10
Quote from: Oldjim
Where's the option to select whether you want the mouse pointer included in the screen shot?
HPsauce
Quote from: jelv
Grin very clever. Roll_eyes
Strat
Fixes: 565
Quote from: Bob
Not available for Firefox 7.0.1
Angry
VileReynard
Fixes: 20
I have Screengrab working on FF 7.0.1.
Strat
Fixes: 565
Well it refuses to install citing my version of FF.
Presumably you installed it on a previous version.
pierre_pierre
and my basic Win 7 aint not got the snipping tool
Included with Windows Vista, Windows 7 (Home Premium, Professional, and Ultimate editions only)[1]
VileReynard
Fixes: 20
Quote from: Strat
I accidentally got onto the beta FF channel - so I reloaded a 3.6 version before going back to 7.0.1
