Windows 7 is completely broken - my laptop won't start
VileReynard
Seasoned Pro
Fixes: 9
It displays a boot-time message to say that something has gone wrong.
It then does the pretty pictures thing, has a progress bar which says it does something very quickly.
It then sits there with the disk light on, displaying some wallpaper (and the mouse moves) Sad
If I use the secret F8 option - was that from Windows 3.1 or Windows 95?
I get about a dozen different options.
All fail.
One even gave me the happy BSOD.
I tried a Ubuntu live boot CD - every works (even networking) whoever set up my virtually brand new (HP) laptop chose to format it with 4 partitions.
The first is a small NTFS boot partition, the second is a big NTFS one, the third is a moderate size NTFS "recovery" partition and the 4th is a tiny FAT32 (?) partition.
Ubuntu says partition 2 is corrupt and that I should run the Windows version of fdisk /f, then reboot twice Cheesy
How can I do this (on a 64 bit machine)?
It's still under warranty. Cry Cry Cry
Addendum:-
I finally got into a command line via something on the recovery partition.
Ran chkdsk /F on drive D: = C:
Cause:- apparently the NTFS bitmap had marked a piece of unused disk as "in-use".
This crashes Windows 7 totally.
It is absolute rubbish.
Wasted 3 hours.
SNAFU Cheesy
Fixes: 19
Re: Windows 7 is completely broken - my laptop won't start
I thought you were dual booting to some flavour of Linux so would not need a boot disc?  Anyway, could it be you have a faulty hard drive?
VileReynard
Seasoned Pro
Fixes: 9
Ubuntu installed as a Windows app. was screwed up by Windows pathetic NTFS filesystem - it failed because Windows had marked the filesystem as "faulty".
severedsolo
do you have recovery disks or an install DVD? put it in the drive, on the "Install now" screen click "Repair My computer" that should give you access to System Restore so you can go back to before you installed WUBI
VileReynard
Seasoned Pro
Fixes: 9
Thanks - but I got it working at the end of last month (see previous post).
The NTFS filesystem is most delicate - and rubbish. Cheesy
severedsolo
sorry  Lips are sealed i didnt see how old the last post was i assumed as it was on the first page it must have been recent lol
