Windows 7 and other languages
- Re: Windows 7 and other langiages
13-11-2011 11:15 PM
I'm aware that you can change keyboard layouts and switch between them but I mean have the OS in Russian.
SWMBO will be inviting a friend here soon and would like to have Russian installed for her as she doesn't understand any English.
I don't want her to have to purchase a copy in Ukraine if we can do it with what we already have here.
Forum Moderator and Customer
13-11-2011 11:24 PM
Install or change a display language
You can change the language Windows uses to display text in wizards, dialog boxes, menus, and other items in the user interface. Some display languages are installed by default, while others require you to install additional language files.
There are two types of language files:
Windows 7 Language Interface Packs (LIPs). Windows 7 LIPs provide a translated version of the most widely used areas of the user interface. LIPs are freely available to download. For more information, including a list of languages available, go to the Microsoft Local Language Program website.
Windows 7 language packs. Windows 7 language packs provide a translated version of most of the user interface.
Before you can install a display language, you need access to the language files. These files can be found on your computer, a computer in your network, or your Windows DVD. They can also be downloaded from the web. For more information about the differences between language packs and Language Interface Packs, and how to get them, see How do I get additional display languages?
Note
Language packs are available in Windows 7 Ultimate through Windows Update as optional updates. They aren't installed automatically. If you're using Windows 7 Enterprise, contact your system administrator for information about installing additional languages.
Link (didn't work in my paste above):
http://windows.microsoft.com/en-US/windows/downloads/languages
13-11-2011 11:34 PM
As far as I know, this is only available in Windows 7 Ultimate. Even Windows 7 Professional doesn't support the language packs, and you can forget about the Home editions.
It's not quite as good as a true regionalised version either (or maybe better, depending on how you look at it). With a native Spanish install, the folder names are regionalised (Archivo de programa instead of Program Files, for example) whereas with an English install with MUI, they all have the original English-language names. Whether or not this becomes a problem depends on software - properly written software shouldn't care. Badly written software making assumptions could fail on either, depending on what it was expecting.
13-11-2011 11:38 PM
You might want to try here to see if you would qualify to purchase a 'student' license: http://www.software4students.co.uk/Software4Students__Am_I_Eligible-article.aspx
and then check this price: http://www.software4students.co.uk/Microsoft_Windows_7_Ultimate_32_bit_Edition_Upgrade-details.aspx (note, this is an upgrade so requires a valid version of windows (XP onward I believe) to already be installed.
13-11-2011 11:38 PM
The other issue is if the software you have actually works with a English/Russian set-up as just changing the OS language on an already installed system does not change the name of the folders, whereas a fully Russian installed system would have the folder names in Russian.
I also know some versions of WIn7 don't support language packs but not sure which ones.
13-11-2011 11:44 PM
13-11-2011 11:45 PM
Further reading took me to this page which confirms they are only available for Enterprise and Ultimate editions.
It also seems that the language can be set to a new user account using Reserve Accounts as per this page.
So this may be the answer. I do have an Ultimate Edition (as yet not used). What isn't clear at the moment is how to undo the changes so that any further user accounts will be in UK English again. Further reading required....
@Peter Yep, I realise that. I did find it strange when I used PCs in Ukraine that so many program's menus and boses were in English rather than Russian.
@walker23 That's how I got the Ultimate edition
Edt: Spelling all over the place as keyboard batteries were getting low
Edit 2: I'm still wondering, though, whether a clean install will allow the full installation in Russian meaning folders will be named correcly?
Re: Windows 7 and other languages
14-11-2011 2:24 PM
Quote from: Mav I don't want her to have to purchase a copy in Ukraine if we can do it with what we already have here.
You might find that a copy purchased in the Ukraine could not be activated in the UK. I certainly had that problem trying to install a Chinese copy of Windows 7 on a computer here. I guess Windows 7 is a lot cheaper in China, so Microsoft does not want these cheap copies exported.
14-11-2011 10:58 PM
15-11-2011 1:17 AM
The earlier ones had the characters rub off quite quickly. My current one has been going for around 3 years with no sign of wear yet.
15-11-2011 8:58 AM
Do you happen to know if the russian wireless keyboards are available in UK? or better still if 'overlays' are available i.e. the rubbery plastic ones which I remember from many years ago.
I have just bought a new wireless set keyboard and mouse and I cannot write the cyrillics on the black keys.
On previous keyboards I have been able to overwrite in permanent felt tip pens.
spasibo.
спасибо ! Ijust found this available on http://winrus.com/screen_e.htm ; !
15-11-2011 11:26 AM
I've never used overlays or stickers personally.
Before I got my first Russian keyboard I used a site like the one in your link. May have even been that one.
16-11-2011 7:39 AM
I think that perhaps the stickers are good for others but I would prefer to use a complete overlay.
I also write only the occasional russian so maybe a total and permanent cover of the keys is a little OTT.
Your help appreciated.
