Windows 7 Update broken
FIXED- Subscribe to RSS Feed
- Windows 7 Update broken
08-12-2017 12:19 PM
WARNING to W7 users - MS Update is borked (see https://answers.microsoft.com/en-us/windows/forum/windows_7-update/error-code-80248015/aeae2fcd-100a... )
I have just rung UK support who -idiots - told me to reinstall Windows, and when I mentioned the thread above, suddenly went all quiet.
Fixed! Go to the fix.
08-12-2017 12:31 PM - edited 08-12-2017 12:31 PM
I thought that was fixed?
https://www.askwoody.com/2017/windows-update-in-win7-now-appears-to-be-working-properly/
Re: Windows 7 Update broken
08-12-2017 12:45 PM - edited 08-12-2017 12:47 PM
Thanks for the heads-up on that one. I was going to update mine later on today but won't bother now.
Do you know if it affects both versions? I run Win 7 x64.
Growing old is inevitable...But growing up is optional.
08-12-2017 12:53 PM
@Pete11 Yes it does -I'm on X64
08-12-2017 12:55 PM
Reading further down the replies, it appears not for everyone.
08-12-2017 1:00 PM
As of a few months ago, a minority of the Windows 7 computers and all the Vista computers I have seen had not manged to install Windows Updates since mid 2016. The process svchost would consume an entire processor core in a vain attempt to find updates whenever the afflicted computer was online. I don't know if Microsoft ever did anything about that particular issue.
08-12-2017 1:16 PM
@ReedRichards This isn't the same issue. The current one revolves around an M$ failure to update one of their own certificates.
08-12-2017 1:19 PM
@Browni I won't know until I check later, but it appears that stopping and restarting WU in services may have fixed it.
08-12-2017 1:25 PM
This also states that MS have fixed the problem.
08-12-2017 1:36 PM
Well, @Browni , it certainly hadn't been fixed at 0830 for me. I actually ran disk check this morning as I had a couple of unrelated niggles, and it wasn't fixed then.
08-12-2017 1:40 PM
08-12-2017 1:58 PM
We shall see, but I had to stop WU in services, alter options to 'never check', run a manual check, then reset WU to automatic, after which it did ANOTHER check, but it seems OK now.
I'll know more tomorrow , if I remember to go back to Control Panel.
08-12-2017 3:29 PM
The November update worked fine for me - December is released next week, I assume?
This site may be helpful for those having problems; it's got me out of trouble in the past when Windows Update seemed broken.
08-12-2017 4:20 PM
Thanks for the info..... however,.... just checked my updates... Running Windows 7 Professional.... I did a "manual" update on Tuesday of a "preview"
Have no problems to date....
09-12-2017 7:59 AM
I have marked this as a fix - following the advice, all now seems well.
