Windows 7 Key
penneck
Windows 7 Key
I've lost my Windows 7 CD (temporarily, I hope). Is there a way of finding out the key from the pc it is installed on?
Thanks for any help
2 REPLIES 2
Fixes: 480
Re: Windows 7 Key
@penneck
Try running Belarc Advisor or Magical Jellybean keyfinder. Both are free downloads.
penneck
Re: Windows 7 Key
Thankyou Baldrick1. Magical Jellybean produced the answer.
Regards
Graham
