Windows 7 Drag & Drop
Fixes: 192
Drag and drop suddenly stopped working. Not sure what caused it but it was after the PC froze for around 1 minute while trying to play a video.
Haven't seen this posted before so did a bit of Google searching and found that if you press and hold on a file with the left mouse button then press Escape with the button still pressed then drag and drop is restored.
Just wanted to pass this tip on.
Forum Moderator and Customer
pierre_pierre
Re: Windows 7 Drag & Drop
for a long time, I have been highlighting a spread sheet line and sliding it over to a web input page, it always left the line on the spreadsheet, for the last few weeks it has been removing it, more work for me, copy then paste. - Win 7
Will try your cure soon
Fixes: 192
Hope it works for you.
I found that my D&D issue only affected Explorer. I killed the program and restarted it to no avail til I found the above solution.
pierre_pierre
didnt work.  Open Office spreadsheet, Firefox 9.01  Win 67
