Windows 7 - Can you put Outlook Express
- Re: Windows 7 - Can you put Outlook Express
08-04-2011 7:26 PM
Can you put Outlook Express on to Windows 7? If yes how?
08-04-2011 7:33 PM
08-04-2011 7:39 PM
Personally I prefer (and use) the "old" 2009 version, though you may not be given that option and have to use 2011.
I think the 2009 version is still available for XP users, though whether you can install it on W7 now I don't know.
08-04-2011 9:10 PM
http://email.about.com/od/windowsemailclients/tp/free_email_prog.htm
Personally I use Thunderbird, it's a bit clunky for Newsgroups but handles email well.
Regards,
Neil
09-04-2011 3:50 PM
09-04-2011 5:34 PM
Quote I think that it can still be got from somewhere on the Internet but not sure where.
It's available at http://www.filehippo.com/download_windows_live_mail/8305/
But you may already know that!
10-04-2011 10:12 AM
10-04-2011 11:28 AM
Personally I find it a bit "retro" and limiting in some areas, though if you're used to Outlook Express it may well seem more familiar than the newer Microsoft alternatives.
Each to their own, but I prefer Outlook 2003, though am actually using 2007 as my main email client.
As noted above I also like and use Live Mail 2009 (& very much dislike 2011).
12-04-2011 4:48 PM
Ehere can I get hold of Outlook 2003?
12-04-2011 4:58 PM
Try here...http://download.cnet.com/Microsoft-Office-Outlook-2003/3000-2367_4-10965633.html
12-04-2011 5:15 PM
Quote from: chandu can I get hold of Outlook 2003?
You need a license from Microsoft. It is NOT free. Outlook alone costs about £80 to £100, or it is some editions of Office - not the student/family ones though.
It is also 2 versions behind current so you'll only be able to buy it from "old stock"
12-04-2011 5:48 PM
I shall have to hunt for old stock. I assume that it will work with both XP and Win7.
