Windows 7 Backup
- Windows 7 Backup
Windows 7 Backup
02-07-2010 7:47 PM
Can one do an incrimental backup with windows 7? After doing the initial backup how does one backup additional files and changes to existing files? Thanks
5 REPLIES 5
Re: Windows 7 Backup
02-07-2010 8:06 PM
Acronis True Image Home 2010 is maybe what you should checkout, Everyone ( over on the windows 7 forum ) recommends it. Heres a link....http://www.acronis.com/homecomputing/products/trueimage/index.html
If life gives you lemons, make lemonade.
03-07-2010 9:03 AM
Quote from: morgan2476 Can one do an incrimental backup with windows 7?
Yes. It happens automatically after the first full backup.
See also http://community.plus.net/forum/index.php/topic,81458.msg666560.html#msg666560
03-07-2010 9:49 AM
Depending what sort of backups you want it's well worth looking at Synctoy, a free Microsoft tool.
03-07-2010 1:11 PM
Agreed. I use W7 backup and system image for the C partition (o.s. and programs) and Synctoy for the D partition (data).
05-07-2010 4:05 PM
Why the need for an additional backup program ?
Is the backup provided by Windows 7 complicated or unreliable or do these other programs make the backup job easier ?
I Have used Acronis in the past (With XP) but on trying to use it with windows 7 I am getting a message that it is not compatable..... likely because it is out of date but before spending my cash on the current version is it something I still need with windows 7 ?
We are born into history and history is born into us.
