Windows 7 Backup
johnmglen
Windows 7 Backup
The backup program that ships with Win7 is stuck in my system tray saying 'Backup in progress,' it isn't in progress, it has never been run and I do not want it.  It's the action centre icon in the system tray that is reporting this.  Quite annoying really, no matter what you do, it always comes back, even stopping services associated with backup, even cancelling notifications about backup, nothing works, even tried running one to completion, still it sits there telling me that it is running.  Driving me mad, Microsoft help is useless too, they said they don't know what is wrong and that I should try the forums!  Great, thanks MS!
VileReynard
All Star
Fixes: 11
Re: Windows 7 Backup
According to the adverts, you, yourself (personally) requested this feature/bug. Grin
johnmglen
Quote from: Taxisofevil
Now that is actually quite funny  Cheesy
