Windows 7 Back Up
- Windows 7 Back Up
Windows 7 Back Up
28-07-2010 3:10 PM
I have a new laptop that i haven't backed up yet. Has anyone does this back up, I was wondering how long it takes and how many DVD's it takes.
5 REPLIES 5
Re: Windows 7 Back Up
28-07-2010 4:55 PM
If this is the writing of the recovery DVD's that the manufacturer ought to have given you, but is too tight-fisted then the answer is:-
1. 4 DVD's (for a Compaq) - includes a lot of HP rubbish.
2. It takes absolutely ages - best to do it when there is a very long film on TV
3. All my DVD's are RW ones - the extra cost for using many times isn't that great. However, these are unacceptable to Windows.
I had to make a special trip to buy a box of 5 DVD's - write once only.
If you use these disks in the future, they can be used to reset your laptop back to the condition it was in before you opened the box.
28-07-2010 5:00 PM
If it is for backing up your data, it depends on:
a) how much information you have to back up
b) how fast your DVD drive is
c) whether you just copy files and folders as they are, or use a compressed archive
etc, etc
Assuming everything you want to back up is in your "Documents" folder, right click on it and click Properties, and it will tell you how much data is in there, in MB. A single-sided DVD holds 4.7GB, or 4,800MB. Divide the size of the "Documents" by 4800, round it up to the next whole number, and you will know how many DVDs you need.
etc, etc
28-07-2010 5:30 PM
Thanks, it is for the recovery DVD's that you don't seem to get with new computers now. I had a feeling it was going to take ages and I keep putting it off. PC World wanted to charge £15 for doing it, along with more money for virus protection and an office package. I declined them all.
28-07-2010 6:32 PM
Use Open Office. It's free.
29-07-2010 1:02 PM
