Windows 2000 v Zenwalk for speed
- Re: Windows 2000 v Zenwalk for speed
17-08-2008 3:35 PM
Would Zenwalk run faster than Windows 2000 SP4?
I am trying to get a bit of life out of a Celeron 333 for a guy for temporary web browsing. The machine originally had Windows 98 but I don't want to use that now as AVG Free 8 no longer supports it. I tried Windows 2000 but by the time I installed SP4 so I could use AVG the computer ran so slow it was almost unuseable. I have used Zenwalk before and know that it is very lite. Would it be much better?
3 REPLIES 3
17-08-2008 3:57 PM
much better. you might also like to try tinyme:
http://tinyme.mypclinuxos.com/forums/index.php
it's even smaller than pclinuxos minime 2008, weighing in at 200mb and using the openbox desktop.
17-08-2008 4:09 PM
Thanks. I am currently installing Zenwalk for a try but also downloading Tinyme. I like the sound of it.
17-08-2008 11:43 PM
Unless you have very little memory win2k should be running fast on that pc you need at least 64 meg but 128meg or above is better. On old pc's I have tried win2k and various linux and win2k is always the fastest. If you only have like 32 meg ram that would be the problem
