Windows 10 "insiders" read this...
- Windows 10 "insiders" read this...
on
02-06-2017
4:24 PM
- last edited on
02-06-2017
4:52 PM
by
Mav
Ooops !... Microsoft release an "update" that could impact on usability of the machine...
Windows 10 blunder - If you get this update from Microsoft DON'T install it
From that page....
"If you received this build (from RS_EDGE_CASE) on your PC: Please be aware that this build was never intended to go out to Windows Insiders and may include issues that impact usability of your PC – more so than the normal builds we give you.
"You can either sit tight and wait for us to publish a newer build to you or you can roll-back to the previous build via Settings > Update & security > Recovery. And check your Windows Insider Program settings.
Moderator's note by Mike (Mav): Quote fixed.
Re: Windows 10 "insiders" read this...
02-06-2017 8:30 PM
03-06-2017 7:38 AM - edited 03-06-2017 7:39 AM
"these builds will not install on devices that are not joined to the Windows Insider Program (a.k.a. 'retail')."
So pretty much a non-story. Any person not running the Insiders build even if offered it would not install. So 99% of Windows 10 users were not impacted by this.
and yes i am on slow ring but did not get this update
03-06-2017 9:10 AM
@rongtw Er.... sorry... I fail to see how you can suggest that the story about MS making a mistake for "insider" users and reporting it, can be a "bit of a "non-story"..
certainly it is a non story for "non insider users"....
. if there was a report that Diesel was not going to be sold on PETROL forecourts... then that would be an important story for diesel vehicle owners...
but certainly a "non-story" for petrol powered vehicle owners...
