Windows 10 , free
- Windows 10 , free
- « Previous
- 1
- 2
- Next »
Re: Windows 10 , free
22-01-2015 11:20 AM
If doing that I'd also think about a separate hard disk for the upgraded system.
22-01-2015 12:49 PM
Quote from: rongtw so i presume after 12 months it will not pass windows activation .
That could prove problematic if a reinstallation needs to be done unless a record is kept of a previous activation within the first 12 months.
Forum Moderator and Customer
22-01-2015 2:49 PM
22-01-2015 5:55 PM
I use Office Enterprise Edition but what is 'Windows Enterprise'?
I'm def tempted by this offer if its possible to do.
22-01-2015 6:12 PM
The Product ID should be in the form xxxxx-xxx-xxxxxxx-xxxxx. What are the 3 characters in the second group (if those 3 characters are OEM, then you have an OEM version).
22-01-2015 10:05 PM
Anyway, pretty happy with 7.
23-01-2015 2:58 PM
It depends how they define the life of the device but it is almost guaranteed that upgrading the motherboard will be classed as a new machine and it is possible that replacing the motherboard with an identical one after the warranty has expired will also class it as end of life of the machine
Quote This is more than a one-time upgrade: once a Windows device is upgraded to Windows 10, we will continue to keep it current for the supported lifetime of the device – at no additional charge. With Windows 10, the experience will evolve and get even better over time. We’ll deliver new features when they’re ready, not waiting for the next major release. We think of Windows as a Service – in fact, one could reasonably think of Windows in the next couple of years as one of the largest Internet services on the planet.
23-01-2015 4:06 PM
what i think we will see is just a basic OS and then if you need to add what they call their Apps they will charge you .
23-01-2015 4:09 PM
23-01-2015 5:02 PM
23-01-2015 5:19 PM
http://www.cclonline.com/product/55272/GFC-02050/Operating-Systems/Microsoft-Windows-7-Home-Premium-...
64 bit OEM
23-01-2015 5:46 PM
23-01-2015 6:50 PM
i cant find the page i read but it sort pointed toward a sort of subscription service , similar to your smart phone where the basic set up is free but add on,s are extra
23-01-2015 6:57 PM
Quote from: rongtw but add on,s are extra
Like IAP's?
Have microsoft been bought out by King.com Ltd?
- « Previous
- 1
- 2
- Next »
