Windows 10 , free
- Windows 10 , free
Windows 10 , free
21-01-2015 5:51 PM
the company decided to offer its upcoming Windows 10 as a free upgrade for existing users of Windows 8.1 and Windows 7. This offer will be applicable only for the first year following Windows 10 launch (after which, Windows 8.1 and Windows 7 users will have to pay to upgrade to Windows 10). Windows 10 will see the return of the Start Menu,
http://www.bbc.co.uk/news/technology-30924022
Re: Windows 10 , free
21-01-2015 5:53 PM
21-01-2015 6:08 PM
Makes it sound as though it will be the equivalent of an OEM license which isn't good news
Quote The upgrade will only be free in the first 12 months after release and will last for the "supported lifetime of the device." Microsoft said the new OS will run on PCS, tablets, phones, and a new device to be announced later today.
21-01-2015 6:28 PM
i still have the win 10 preview on another PC an must say i like it
21-01-2015 6:30 PM
Windows 10 will be a free upgrade from Windows 8.1, Windows Phone 8.1 and Windows 7 for the first year. That last bit is huge as Windows 7 is found on nearly half of all Windows-based PCs. And once a device is upgraded to Windows 10, it’ll be supported for the lifetime of the device. It's a move that'll no doubt drive adoption sky high in the first year.
21-01-2015 6:32 PM
For domestic users with Windows 7 there will also be some attraction given the extended support and features upgrade path it will offer.
The preview I have installed on a fairly old system seems to work well, though I still prefer the visual aspects of Windows 7.
21-01-2015 7:07 PM
Windows 8 one of it's problem's was it was "too soon".
At windows 8 launch I didnt require anything it offered and it had too many downsides for me.
However things will have changed on Windows 10 launch.
21-01-2015 7:52 PM
Couldn't find info on that.
Forum Moderator and Customer
21-01-2015 7:56 PM
Also mean's Cortana is now making the leap from Window's phone on to computers.
I already use Cortana for a few things on my Windows phone, im looking forward to the Windows 10 software upgrade for both my PC & phone
21-01-2015 11:03 PM
Mav if i read it right yes upgrade to win 10 free if you upgrade in first 12 month , after then you will pay
21-01-2015 11:21 PM
I assume the latter as you may need to re-install anyway at some stage but it isn't clear - not to me, anyway.
21-01-2015 11:32 PM
Like could I install windows 10, activate it, make an image to put to one side, then maybe go back to reload an image of my activated windows 7.
22-01-2015 8:38 AM
but if you do it after the first 12 month you have to pay , so i presume after 12 months it will not pass windows activation .
The offer is strictly limited, and apparently doesn't extend to OEMs or Windows Enterprise users,
also DX 12 will only run on windows 10
22-01-2015 9:04 AM
That sounds very likely to work if you want to hang on to W7 for a while.
Quote from: billnotben could I install windows 10, activate it, make an image to put to one side, then maybe go back to reload an image of my activated windows 7.
If I had just one W7 (orW8) system I'd wait a while to see what others experience, there will no doubt be a few glitches.
But I have several (five W7 plus one W8.1 I think), so I'll probably update the least important one first and see what I learn from that.
22-01-2015 11:16 AM
That could depend on what Microsoft do with "activation checks". Win 7 seems to check its status every time you boot if there is a connection available (as I found moving from dual boot to a more flexible virtual machine set up for Win7).
