Windows 10 crash
- Windows 10 crash
Windows 10 crash
17-02-2020 9:14 PM
The "crash" was my computer monitor which fell off its stand while I wa strying to clean around it ! Sadly, it bent the HDMI cable plug and pulled all the connector fingers out of the connector. There was no way I was going to be able to put about 20 fingers back in, and so decided to swallow my pride and go and buy a new HDMI cable for £20 from PC World - the cheak !
When i got back and tried to start the computer, Windows 10 automatically went into some "repair" mode, scanning the hard disk while I bit my finer nails. It started slowly up to about 5% and then went rapidly from 5% to 50% where it stopped again for a good five minutes; the same happened with 51%-55%, and then it ran reasonably quickly up to 100%.
I waited with trepidation while it started up and eventually all seemed to be o.k. - except the audio which uses external speakers. I fiddled about for some time and eventually discovered that audio settings had changed from audio out to audio in. When I changed the settings back to audio out, everything worked o.k. as far as I know.
Anyway, my question is what happened and why ? Was this all associated with ripping out the HDMI cable and re-inserting a new one ? Am I likely to have done any permanent damage, especially to the hard disk ? It is all very strange but it seems to working o.k. again now - it took me a good hour of fiddling and hair going greyer than usual to get there though !
Re: Windows 10 crash
17-02-2020 9:57 PM
My guess would be that during the drop HDMI pins got shorted together causing the software acrew up. It is very unlikely to have of caused any hardware damage so I wouldn't worry about it. However keeping a regular backup of your hard disk should be a basic and regular data protection precaution. It amazes me how many people don't bother then feel hard done to when they lose all their, for example, photos.
17-02-2020 10:24 PM
Thanks Baldrick1
That is very helpful.
I am very good about backing up all my data regularly (d:), but not my Windows System (C:) and I pleade guilty as charged.
What is the easiest way to back up the system using either an extrenal hard disk or even DVDs ? Can you recommend something even an idiot like me can (and will) do ?
Thanks.
17-02-2020 11:12 PM
To be honest I do not keep a back up of my system disk. I use a free application such as Belarc Advisor to extract the Licence Numbers and Activation Codes for all the applications I have installed, this I print out and keep safely. If my C: drive was to fail I would take the opportunity to do a clean install of Windows, I do this periodically anyway. It's a bit of work but cleans out all the old dross and stuff I no longer use. The only thing is that these days you need a decent broadband connection to download the latest versions of programs.
Hard drives are really cheap these days. Rather than backing up a system disk I would simply use a spare disk and clone it using free cloning software. For a system disk you can get a 128GB SSD for under £20. With this and a USB to SATA interface cable (USB3 preferably) you can clone a system disk in a very short time.
If the system disk fails you can use the cloned disk by simply swapping them over.
18-02-2020 7:58 AM
@shermans Without a monitor on your PC I assume you just turned off the power? If you did then this would explain why it went in to recovery mode when the power was restored.
As suggested by @Baldrick1 as USB disk is your quickest and cheapest option along with a notepad to record program registration detail.
But please tell me you didn't pay £20 for an HDMI cable, Tesco or the other mainstream stores will sell you one for about £5.
