Windows 10 backup
VileReynard
Fixes: 20
Windows 10 backup
My daughter bought a laptop from Curry's - big mistake.
At my urging she took a backup to an external disk using "Windows Backup" - ran for absolutely ages.
After Curry's wiped/replaced her 1TB disk in order to fix a broken screen connector [?],
It turns out that this so-called backup software didn't backup any data.
Is there any Windows software that can backup a disk to external media?
Why wasn't proper backup software included in W10?
5 REPLIES 5
Fixes: 1,482
Re: Windows 10 backup
There is backup software included in w10 - swmbo's laptop backs up to a drive attached the router.
It only backs up user data and not system data, so not sure what your daughter has run.
VileReynard
Fixes: 20
Thanks - I'll have to talk to her about it.
daveplus
Fixes: 10
@VileReynard
https://www.techradar.com/best/best-free-backup-software is worth a look. I have been using Paragon for years and it has never let me down. There are plenty of others: AOMEI is pretty good https://www.backup-utility.com/free-backup-software.html
Dave
@VileReynard - Maybe this link will help you and your daughter.
https://www.windowscentral.com/how-backup-windows-10-automatically
VileReynard
Fixes: 20
@Anonymous I'll see if she can try your link - it seems very detailed.
