Windows 10 and a Webcam
- Re: Windows 10 and a Webcam
02-08-2015 9:25 PM
Preferably a 720P resolution type with built in microphone.
I currently have a Logitech C270 which has performed well on Windows 7 but on W10 with any available driver it's a problem, hence the question.
02-08-2015 9:28 PM
02-08-2015 9:46 PM
02-08-2015 11:26 PM
What problems are you having?
03-08-2015 11:13 AM
As I mentions elsewhere, a Skype call is out of the question because the other end can't make out what I say.
I discovered the Camera app in Windows 10 and tried that.
A recording a moment ago runs fast audio and video.
A run through various settings in 'Sound' and the Realtek Audio Manager without changing any settings.
It then works until I unplug the Webcam and reconnect it or do a reboot.
03-08-2015 11:54 AM
Quote from: Strat I discovered the Camera app in Windows 10 and tried that.
I tried two short recordings but the audio and video was perfectly normal.
Am I correct in thinking you have exactly the same webcam as me?
03-08-2015 12:28 PM
Although how you would change that I haven't a clue!!!
York.
03-08-2015 2:20 PM
@NedLudd Me neither.
I have had video running normally with speeded up sound and others with both sound and video speeded up.
It's a strange one to be sure.
Looking at the drivers installed there is a selection of Microsoft and Logitech entries present.
03-08-2015 4:24 PM
Following advice in a Logitech forum I visited Control Panel > Sound > Recording > Microphone > Properties > Advanced and changed Default Format to 1 channel, 16 bit, 16000Hz (Tape Recorder Quality)...it was set on 48000Hz.
Recordings were ok...even after a reboot.....fingers crossed.
03-08-2015 4:31 PM
This is for a 10 year old Creative Labs camera!
York.
03-08-2015 4:34 PM
=== Start of device information =======================
Device name: Logitech HD Webcam C270
USB Vendor ID (VID): 0x046D
USB Product ID (PID): 0x0825
USB Revision (BCD): 0x0012
Firmware Version: 7.1.1010
Firmware CRC: 0x6343
EEPROM Version: 1.27
Sensor Type: 2.0
Driver Version: 13.80.853.0
=== End of device information =========================
My microphone format is set to 48000 Hz without any problems so far.
03-08-2015 4:47 PM
USB Revision (BCD): 0x0010
Firmware Version: 6.0.1133
Firmware CRC: 0xD4CA
EEPROM Version: 2.22
Sensor Type: 2.9
A few small but significant differences.
Incidentally I went to select Webcam in Device Manager > Sound, Video and Game Controllers which is where it was located, but it wasn't there
I found it in Imaging Devices which is where I presume yours is located.
03-08-2015 5:56 PM
Quote from: Strat I found it in Imaging Devices which is where I presume yours is located.
Yes. And it looks as if my model, although nominally the same as yours, is actually a bit different.
03-08-2015 9:39 PM
Quote from: NedLudd Hmmm, mines set at 2 channel, 16 bit, 48000Hz (DVD Quality)!
So was my Logitech in Windows 7 but that was back in the good old days
03-08-2015 9:41 PM
