Windows 10 Threshold 2
ReedRichards
Seasoned Pro
Fixes: 25
A significant update to Windows 10 called 'Threshold 2' (Th2) has now been released to Insiders and should go on general release soon.  It changes the Windows 10 version number to 1511 (year & month).  Supposedly it contains a lot of bug fixes and a little bit of visual restyling, which you may or may not notice.
16 REPLIES 16
rongtw
Fixes: 12
Re: Windows 10 Threshold 2
Yes i got it this morning  Wink  also i noticed insider watermark has gone
NedLudd
Windows 10 Pro 64bit.
I've just had a massive update but I find I'm still on 10586, although that does not show on the desktop anymore???
As you were! A reboot shows:-
Version is 1511 - Build is 10586!
Geoff,
York.
anniesboy
Name changed to " Windows 10 Fall" to be released Thursday 12th?.
Info    http://www.windowscentral.com/whats-new-windows-10-fall-update
ReedRichards
Seasoned Pro
Fixes: 25
You mean after it wasn't released on November 11th like the rumours had said?
nadger
Quite surprised it was available on my £60 Linx 7 this morning  Smiley
VileReynard
Fixes: 20
So Windows 10.1 is out - already?  Grin
rongtw
Fixes: 12
Nope sorry Foxy ,, its just a Update its still win 10 , and it will stay  win 10 as they are just doing continuous updates
HPsauce
Weird, it appeared on one of my systems as an update, alongside something else, but never got applied and disappeared!
Still on 10240. W10 Pro that system.  Crazy
No sign of it on other systems.
rongtw
Fixes: 12
Mine says win 10 pro , version 1511 , Build 18586.3
ReedRichards
Seasoned Pro
Fixes: 25
Just took several hours to install on my little netbook.  I wonder if it kills your ability to roll-back to your previous version of Windows (if you are still within the 30 days when this is supposed to be possible)?
alanf
If I recall what I read correctly the update will not install on a machine on which Windows 10 has been installed within the previous 30 days.
Strat
Fixes: 565
Just run the install of build 10586 and it kicked my CPU-Z off the PC as 'incompatible with this version of Windows 10'.
I installed a fresh copy which works ok.
nadger
Took 4 hours to complete update yesterday on my HP laptop
Does seem to be running ok
HPsauce
Quote from: Strat
Yes, same here, bit bemused by that. It wasn't an old version, just not the very latest.
