Windows 10 Threshold 2
- Re: Windows 10 Threshold 2
06-11-2015 7:47 AM
06-11-2015 12:41 PM
06-11-2015 3:06 PM
I've just had a massive update but I find I'm still on 10586, although that does not show on the desktop anymore???
As you were! A reboot shows:-
Version is 1511 - Build is 10586!
York.
11-11-2015 4:30 PM
Info http://www.windowscentral.com/whats-new-windows-10-fall-update
11-11-2015 11:27 PM
13-11-2015 3:21 PM
13-11-2015 4:21 PM
13-11-2015 5:43 PM
13-11-2015 8:57 PM
Still on 10240. W10 Pro that system.
No sign of it on other systems.
14-11-2015 6:53 AM
14-11-2015 8:22 AM
14-11-2015 2:49 PM
15-11-2015 12:09 AM
I installed a fresh copy which works ok.
15-11-2015 10:39 AM
Does seem to be running ok
15-11-2015 3:45 PM
Yes, same here, bit bemused by that. It wasn't an old version, just not the very latest.
Quote from: Strat Just run the install of build 10586 and it kicked my CPU-Z off the PC as 'incompatible with this version of Windows 10'.
