Windows 10 Solitaire
gleneagles
Aspiring Legend
Fixes: 17
Is it true that if you want to play Solitaire free of adverts on windows 10 it wil cost you £ 1.19 a month ?
We are born into history and history is born into us.
5 REPLIES 5
Oldjim
Resting Legend
Fixes: 63
Re: Windows 10 Solitaire
yes as reported in the Times
The card game, which has soothed stressed office workers and entertained bored students since 1990, now costs £1.19 a month or £7.69 a year unless gamers can stand interruptions by 30-second adverts between hands.
and also here http://www.dailymail.co.uk/sciencetech/article-3180657/Microsoft-fire-Windows-10-users-playing-Solit... and they have just come up with a very good reason not to move from 7 to 10
HPsauce
Seasoned Pro
Fixes: 4
Just copy the old XP version (which is much better) from an old XP system System32 directory.
IIRC you just need sol.exe and cards.dll, put in the same folder anywhere you like on you non-XP system.  Wink
Oldjim
Resting Legend
Fixes: 63
Anyone tried copying the Win 7 spider solitaire etc. to Win 10
gleneagles
Aspiring Legend
Fixes: 17
@HPsauce,
Would it be that easy?
If you were using windows 7 or 10 how could you extract something off a windows XP installation disk ? other than installing it on a second computer and then copying the necessary files ?
HPsauce
Seasoned Pro
Fixes: 4
It is that easy if you have access to an XP installation disk (running or slaved to another system). No doubt someone somewhere will have it online to download.
e.g. http://vail-computer-repair.com/2012/12/windows-xp-version-of-solitaire/
