Windows 10 Own Goal?
- Windows 10 Own Goal?
04-08-2015 11:42 PM
Re: Windows 10 Own Goal?
05-08-2015 7:09 AM
The main MS problem is that they have made a mess of Activation process , i was on the insider program previous to doing a fresh install with their media creation tool to a USB ,, now i cant get win10 to activate
05-08-2015 8:22 AM
The new browser needs tidying up to reduce "real estate" waste (and I use a 24" monitor) - I have re-instated IE11
At the moment, it takes a long time to boot, compared with the Win7 it downgraded, and then spends a lot of time thrashing the disk after I log in - perhaps it is upset by lack of internet access
Phil
* I cannot justify classing the change as an "upgrade".
05-08-2015 11:20 AM
That said, I've been running Windows 10 for a week now and haven't found anything wrong far apart from a couple of insignificant glitches. All my hardware runs OK with the exception of an old USB wifi adapter. Win 10 boots up a bit quicker than WIn 7 and programs seem to load quicker. Somehow it feels more responsive. I particularly like the rapid response from the Search box when looking for a rarely used App and it seems a bit faster than Google with Web searches (although I prefer the Google results to the Bing ones).
I can't see any reason to revert my old favourite Win 7. Windows 10 does it all as well or faster and has some additional goodies.
05-08-2015 12:33 PM
Quote from: ffox .... I particularly like the rapid response from the Search box when looking for a rarely used App and it seems a bit faster than Google with Web searches (although I prefer the Google results to the Bing ones).
I thought the same the first time I used it, but thereafter it only gave internet results
05-08-2015 12:46 PM
I've found a workaround for my webcam issue and this forum provided the solution to my Outlook problem so things are looking up.
Hmm....this post is sounding like the contents of an Elastoplast box but I'm sure we will get there...eventually.
Edit: Thanks again to this forum I have found IE on my W10 PC and it's still configured for my IPCam so that's another workaround sorted
05-08-2015 1:08 PM
I'm still running IE as my Norton Password Manager cannot integrate with Edge.
Both machines have (old) ATI graphics and have updated Okay!
I like it (so far)!
York.
05-08-2015 1:30 PM
05-08-2015 2:01 PM
Otherwise upgrade went well enough, it has fixed a few problems on my 5 y/o laptop. All my programmes (sorry, "apps" as we apparently now have to call them) seem to work as before. I don't particularly like the new browser or mail client, so I'll stick with Palemoon and Thunderbird
05-08-2015 3:33 PM
05-08-2015 3:51 PM
So.. after a very frustrating day... (particularly on the old Dell machine) getting it installed... I have found the "Get Me Out Of Here" button... and gone back to Win 8.1 ..... I won`t be staying there either... as soon as I dare...... or ... when the warranty runs out... I shall be wiping the hdd and installing a 64 bit copy of Windows 7... and then getting the drivers from DELL Support for the rest of it.. ( if I haven`t already got a DVD from them by then... )...
To sum up... for the basic use I have... Win 10 is just a waste of time and effort.... Not sure about gaming and othere techy stuff, like motherboards and graphics cards.. cos I don`t do that ... but it seems that there are issues with those guys who do....
Best of luck, if you get Win 10 and can "get along with it"...... I am going home ! ! ! ....
05-08-2015 5:14 PM
Both upgraded to Win 10 without any significant problems, in fact non of the problems were hardware related!
York.
05-08-2015 5:16 PM
Quote from: shutter n those programs worked perfectly before microsoft re-wrote the O.S. so that they don`t... ?
.... but that allows the other software developers to sell you an updated version
05-08-2015 5:34 PM
06-08-2015 2:42 PM
