Windows 10 Calling Home
Fixes: 4
Anybody know if it's possible to stop it from calling home ?Huh
And what is that all about ?
17 REPLIES 17
rongtw
Fixes: 12
Re: Windows 10 Calling Home
i dont see them connections on my win 10 ?Huh
but defiantly MS , first ip is in Dublin  Ireland   2nd is in Washington   USA
Fixes: 40
@30FTTC06 are you running Bing and or Cortana on your PC? As this might explain these connections and as @rongtw says they belong to MS, so it may well be related to the aforementioned due to the secure port their using.
aramil
SearchUI is cortana checking news feeds/interests etc (against you account details etc)
Explorer is online storage checks (onedrive)
Fixes: 4
Cheers Guys,
 I try not to use all that dross but I do use the search window quite a bit for files on my machine and programs of course!
However today thinking I'll do battle with it... it has wound it's neck in (Microsoft) and run off.
Here is what I did previous to posting this thread from various sources around the web.
Change:
sc config diagtrack start= disabled
sc stop diagtrack
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\DataCollection
AllowTelemetry 0
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Windows Search
AllowCortana 0
Change privacy settings in Windows’ Settings app
Disable telemetry in the registry
Open a command prompt as Administrator, then type:
The space after start= is a must
       sc stop diagtrack
Services changes - Hold the Windows key and press R, then type services.msc and choose OK.
Background Intelligent Transfer Serivce – Automatic (Delayed Start) -> Manual
Connected User Experiences and Telemetry – Automatic -> Disabled
Diagnostic Policy Service – Automatic -> Manual
Internet Connection Sharing (ICS) – Manual (Triggered) -> Disabled
Windows Biometric Service – Automatic -> Manual
WLAN Autoconfig – Automatic ->
    Click START, type REGEDIT.EXE and press ENTER Key
    Expand KEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsStore
    Right click and select NEW > REG_DWORDblock-windows-store
    Name it RemoveWindowsStore
    Set the value to 1
As you can see it's clean today, I don't see why Microsft needs to be connected to my pc all the time.
That said I know that Apple do this, But I think I trust them More <<< did I just say that¬ meh!
bin
Seriously?
Microsoft=Apple=Google/Android  'All your data are belong to us'
You are not a customer - your are an exploitable resource - get used to it.
There are a huge number of registry entries you can fiddle with to your hearts content to prevent Windows call home - all of which will be re-set by MS on the next available update - get used to it.
Fixes: 40
The following is based on (I assume) the same source as that of @30FTTC06 in Msg 5 but that post doesn’t really explain the process (sorry) so I hope the following will help.
First off if you do any of this, you do it at your own risk, so the first thing you should do is create a backup of your entire PC and or the registry. To back up the PC use your own solution or software of choice and for the registry you can either back up the section you’re editing (using r right click and Export) or create and use a System Restore point, the choice is yours.
Add Registry Keys :
Data Collection:- HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\DataCollection Create a 32Bit DWORD key called AllowTelemetry with a value of 0 Cortana:- HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\Windows Search Create a 32Bit DWORD key called AllowCortana with a value of 0
Windows Store:-
KEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\WindowsStore Create a 32Bit DWORD key called Block-Windows-Store with a value of 1 To disable Windows Telemetry you can use SC CONFIG to stop Windows 10 from phoning home. sc config DiagTrack start= disabled sc config dmwappushservice start= disabled Reboot for these to take effect. Or use these two commands to terminate the services now. sc stop DiagTrack sc stop dmwappushservice Some service changes are also needed so with the Windows Key + R enter services.msc then click OK. Now set the following options; the value after the -> is what you need to set the ’Startup Type’ value to. To do this find the entry in the list of services and double click on it. If it’s not selected by default you want the ‘General’ tab. Background Intelligent Transfer Serivce -> Manual Connected User Experiences and Telemetry -> Disabled Diagnostic Policy Service -> Manual Internet Connection Sharing (ICS) -> Disabled Windows Biometric Service -> Manual WLAN Autoconfig -> Manual
 Hope this helps.
SpendLessTime
Aspiring Hero
Fixes: 82
If you would prefer a program to help control the Microsoft call home then give Spybot Anti-Beacon a shot https://www.safer-networking.org/spybot-anti-beacon/
Anti-Beacon is small, simple to use, and is provided free of charge. It was created to address the privacy concerns of users of Windows 10 who do not wish to have information about their PC usage sent to Microsoft. Simply clicking “Immunize” on the main screen of Anti-Beacon will immediately disable any known tracking features included by Microsoft in the operating system.
If any issues occur with your PC while using Anti-Beacon, undoing the changes made can be done by clicking the “Undo” button in the main window. This will re-enable all tracking services. If you experience any issues using Anti-Beacon or have any suggestions/recommendations, please be sure to let us know
NorthPole
Fixes: 6
As an alternative, O&O ShutUp 10 does something similar - free and very simple to use.
rongtw
Fixes: 12
some handy tips here Smiley  http://www.techspot.com/article/1336-disable-windows-10-ads-annoyances/
Fixes: 4
Sorry guys, those were my notes that I was sharing.
Thanks @Mook for taking the time to reflect on my notes.
VileReynard
Aspiring Champion
Fixes: 15
In a trial, I configured the internet connection as a dial-up connection.
This appeared to stop phoning home.
Fixes: 40
Glad to help @30FTTC06 it may not be as easy or convenient as the software options but at least you know what is being done, and of course, how to undo it.
Fixes: 4
Ireland calling!
explorer.exe 3900 192.168.1. 1544 40.77.229.60 443
dig -x 40.77.229.60
db5sch101110245.wns.windows.com.
creepy...
2017-05 Cumulative Update for Windows 10 Version 1607 for x64-based Systems (KB4019472)
Fixes: 4
How can I see what service is associated with explorer.exe
tasklist /svc
MsMpEng.exe                   2260 WinDefend
unsecapp.exe                  2792 N/A
WmiPrvSE.exe                  2908 N/A
NisSrv.exe                    2928 WdNisSvc
sihost.exe                    3608 N/A
svchost.exe                   3636 OneSyncSvc_4e570
taskhostw.exe                 3708 N/A
PresentationFontCache.exe     3808 FontCache3.0.0.0
explorer.exe                  4048 N/A
RuntimeBroker.exe             3080 N/A
igfxEM.exe                    3268 N/A
ShellExperienceHost.exe        604 N/A
SearchIndexer.exe             2504 WSearch
