Win XP-HTTP Problem
ajr
Win XP-HTTP Problem
How can I swich on HTTP.
A web site I visit has pictures which I wish to Look at. On the page where the picture should be is a sall box with a X in it , top LH side.  see its a HTTP file.
I have checked with a friend to ensure the site is OK, and he can see the Photo's.
Any ideas, Ihave tried tools -  internet options, but with no obvious selection button Embarrassed
Fixes: 247
Re: Win XP-HTTP Problem
can you post the link? You can't switch on HTTP it is a protocol not a program.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
pierre_pierre
and is it e-mail or web
and which browser
if its e-mail you might have an option that says view HTML, depends on the program you are using
right click on the offending image and check properties, it might be in a format that you havnt got a reader for
ajr
Its Internet Explorer  Web site is" anfi.com" >Resort Guide > Take a 360 degree.....>Club Puerto or any other tour.
I then get the page with the red X in the box. Embarrassed
Fixes: 247
Seems to work ok here I'm afraid.
Do you have flash player installed as that is what it requires.
pierre_pierre
mines running slow and it shows that it is a Java picture show
have you got Java
pierre_pierre
source shows it to be a Gif file with Java movement
<META NAME="Description" CONTENT="Take a look inside of Anfi Beach Club">
<link rel="STYLESHEET" type="text/css" href="../../css/estilos.css">
<script src="../../js/funciones.js" type="text/javascript"></script>
</head>
<body topmargin="0">
<!-- tabla TOTAL -->
<table width="770px" align="center" cellspacing="0" cellpadding="0" border="0" id="tabGen">
    <tr>
<td align="center">
    <form name=formSearch action="http://www.anfi.com/front/EN/src/search/search.asp" method=post>
<table id="tablasup" cellspacing="0" cellpadding="0" width="770px">
    <tr>
<td id="logo"><a href='http://www.anfi.com/front/EN/src/home/home.asp'><img src="../../imagenes/logoENG.gif"
width="139" height="113" border="0" alt=""></a></td>
<td id="banner" background="../../imagenes/clubanfi.jpg" height="145px" width="629px"></td></tr>
    <tr>
<td colspan="2" bgcolor="#A38C48">
    <a href="http://www.anfi.com:80/front/EN/src/about_anfi_group/aag.asp?N2=OVW&N1=COMP&N0=AAG"
><img src="../../imagenes/botones/ENG/acercaoff.gif"  height="17" alt="" border="0"
onMouseOver="sobre(this,'acerca','EN')" onMouseOut="fuera(this,'acerca','EN')"></a><a
href="http://www.anfi.com:80/front/EN/src/membership/mbs_aboutMS_vacationMS.asp?N1=AMS&N2=VMS&N0=MS"
><img src="../../imagenes/botones/ENG/afiliacionoff.gif"  height="17" alt="" border="0"
onMouseOver="sobre(this,'afiliacion','EN')" onMouseOut="fuera(this,'afiliacion','EN')"></a><a
href="http://www.anfi.com:80/front/EN/src/anfi_vacation_club/avc.asp?N2=WLC&N1=AAVC&N0=AVC"
><img src="../../imagenes/botones/ENG/anfivacationoff.gif"  height="17" alt="" border="0"
Fixes: 247
nope, not Java...
  <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
        codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,29,0"
width="373" height="25">
        <param name="movie" value="Botonera.swf">
        <param name="quality" value="high">
        <embed src="Botonera.swf" quality="high"
      pluginspage="http://www.macromedia.com/go/getflashplayer"
      type="application/x-shockwave-flash" width="373" height="25"></embed>
        </object>
ajr
Thanks everybody  problem solved following download of latest Java Smiley
