Win Vista keeps rebooting
- Re: Win Vista keeps rebooting
13-10-2012 5:28 PM
Any ideas please
13-10-2012 5:44 PM
13-10-2012 7:19 PM
13-10-2012 8:37 PM
13-10-2012 9:23 PM
If that fails then a reinstall.
As for no install disks, maybe how he got the trojan in the first place. If it is a legit windows and was pre installed it will have a hidden partition on the pc, they come with a repair disk to trigger the repair/re-install. If he got it second hand then another lesson for him, make sure you get the disks.
13-10-2012 10:28 PM
To Gus - my son bought the laptop brand new about 4 years ago. He didn't create recovery disks because he was just too lazy (you can't tell a teenager anything - try it sometime), so it isn't a case of buying second hand. However, when there's a problem, he eventually comes to me. Usually I I can fix it, but this one has me beat.
I have had a look at that site you suggested. Their English isn't all that good so they may not explain themselves very clearly. I'm a little concerned that in Step 3 of their instruction, they appear to be suggesting removing files such as "win32rundll.exe", "C:\windows\system32\services.exe", "C:\windows\system32\drivers\ipinip.sys" - wont the laptop need those? If I haven't got any recovery disks, if I need to put them back, where do I get them from?
If I can find reinstall disks from someone who has a laptop with Vista on it, will they work on my son's laptop?
13-10-2012 11:12 PM
14-10-2012 1:22 AM
Go to the startup tab and disable everything that isn't Microsoft (I think there may be a button to do this, or a button to show/hide Microsoft components), save the settings and on the next reboot there is a chance the virus won't be running.
At that point do a scan with MS Security Essentials, and I'd throw in MalwareBytes AntiMalware in for good measure.
14-10-2012 8:14 AM
If it will run, System Restore is always the best option and your best chance of getting it to run is from 'Repair Mode' (not available in XP).
14-10-2012 9:00 AM
I will try ReedRichards virus removal rescue disk.
I have wondered if a temporary install of XP to overwrite the C: drive would allow me to get to where I can create recovery disks from his hidden partition. Any thoughts?
14-10-2012 10:30 AM
Installing XP won't work as you hope.
Edit: The Recovery Discs are for when your hard drive fails so the recovery partition is lost.
14-10-2012 11:44 AM
14-10-2012 2:57 PM
I assume the laptop is 32 bit, not 64
14-10-2012 3:13 PM
Run it, click 'Next' and select 'as an ISO file on a disc (Advanced)'
Chose a place to save the ISO. (I put it on my desktop)
Burn the ISO image to a disc.
Restart the computer booting from the disc you have created.
I have just tried it with no problems.
14-10-2012 5:31 PM
My DVD R/W drive and Nero 7 may be a bit long in the tooth, but I don't see why they should be causing problems.
