Win 7Pro Changing Password.
FIXED- Subscribe to RSS Feed
- Re: Win 7Pro Changing Password.
26-02-2018 4:06 PM
Being guilty of maintaing a simple password at starting a session, I looked up the procedure for changing and found that it needs to have a clean USB drive to be plugged in to go on. It did not like the drive telling me that it needs to be a password reset disk. This was not a requirement in the Handbook. Anybody found the way to go?
Fixed! Go to the fix.
26-02-2018 9:13 PM
I'm not sure I understand the question; which is possibly the cause of your getting an odd answer when looking it up. You can change a User Account password by going to Control Panel > User Accounts and Family Safety > User Accounts.
28-02-2018 12:56 PM
Thanks for the advice to use to use the Conrol Panel/User Accounts/Change the Password which works fine.
The Win7 Handbook also sugested entering the Password twice and type in the new Password. This is where the need to have a Password Drive arose. It offered a USB. drive or floppy (not got one) so I put in a clean USB drive which it rejected it because it was not a "Password Drive". Hence my question.
Colin
28-02-2018 3:33 PM
Glad to help. I think what you were reading pertains to how to deal with a forgotten password, not how to change a password you know to a different one.
