Win 7 run a DOS commnd as administrator.
journeys
How do I "As a Administrator open a Command Prompt and run "SFC /SCANNOW"?
I can get the command prompt OK, I try to run the command and get the message "You must be administrator".
There is only one user of the PC.
8 REPLIES 8
HPsauce
Re: Win 7 run a DOS commnd as administrator.
Ctl-Shift-Enter
Kelly
Fixes: 9
type cmd in the search box on the start menu and leave it a few seconds.  When cmd.exe appears in he programs list, right click it and select run as administrator
Kelly Dorset
Ex-Broadband Service Manager
journeys
@HP, @kelly, thanks
7up
Fixes: 17
Quote from: Kelly
You get the award for most helpful tip! Thanks for that, it'll come in useful at some point!
MJN
Fixes: 5
With all due respect to Kelly for providing a correct (and obvious) answer, HPSauce's response is pure genuis. Who would've thought that terminating the command with CTRL-SHIFT-ENTER would run it with elevated privileges?! That's definitely one to make a mental note of.
Mathew
HPsauce
Quote from: MJN
It's fairly well known - in certain circles.  Lips_are_sealed
MJN
Fixes: 5
I would never have found it out without being told.
Does this now make me a part of the circle?!
RPMozley
Fixes: 13
Quote from: MJN
Yeah, and death to anyone that tries to break out of it!  Grin
That's RPM to you!!
