Win 7 USb issues
- Win 7 USb issues
- « Previous
- 1
- 2
- Next »
Re: Win 7 USb issues
19-09-2012 9:31 AM
Thanks for that. Will try it later on, and let you know...
19-09-2012 11:30 AM
Well USBDeview worked a treat.. Uninstalled a load of devices I never use anymore, and also the software for the suspect USB stick. Put it back in, it installed device software, and worked within seconds..
Thanks VERY much.
Thanks VERY much.
19-09-2012 4:48 PM
@ sprite.
Sorry about the mistyping, had Win 98SE in the background of what is left of my mind!
@ wisty,
It looks like the progs that you list might help me as well I guess. Will see when I have time.
C.
@ wisty,
C.
19-09-2012 10:06 PM
Pleasure!
USBDeview has helped me many times!!
20-09-2012 3:01 PM
I have severe download difficulties at the moment, yet to be resolved, which deter me downloading anything right now. As soon as Anotherone gets home from visiting me in West Wales we might see light at the end of a very long tunnel. When the dust settles will have a go.
Thanks.
Thanks.
20-09-2012 7:02 PM
You can make Device Manager show everything with a couple of steps:
1. Create a system environment variable called devmgr_show_nonpresent_devices with its value set to 1.
2. Then open Device Manager and tick "Show Hidden Devices" under View in the menu.
- « Previous
- 1
- 2
- Next »
