Win 7 Pro updates taking "forever"
FIXED- Subscribe to RSS Feed
- Win 7 Pro updates taking "forever"
Re: Win 7 Pro updates taking "forever"
09-01-2017 12:18 PM
I have noted all the above with some alarm. My Win 7 Pro usually installs updates on its own delaying the action of shutting down. It seems an age since it has done this. Where can I look to see the listed updates and what may be not installed? I have always assumed that this job was automatic but your experiences suggest that it has ceased to be.
Advice will be welcomed please.
09-01-2017 1:28 PM
This thread is mainly about Win7 taking 'forever' to search for updates (in my case using 50% of available CPU whilst doing so), and then usually failing to find any.
Easiest way to check whether yours are up to date is to go to Control Panel > System and Security > Windows Update > View update history.
This will show the most recent updates - mine were the scheduled ones on 14/12/2016.
11-01-2017 4:55 PM
@ JayG
Thanks for that. When I have five minutes I will have a look.
11-01-2017 5:52 PM
Just to update the update record there were 2 further updates today which logic suggests you should also receive, one of which was the Jan 2017 roll up (don't ask - stopped trying to make sense of MS updates years ago!)
11-01-2017 8:25 PM
@JayG proably got that today on this machine, as it is "active".... but will have to dig out the other machine ( the one that was the cause of this thread originally ) from hibernation in it`s box, under the stairs ! ! . Probably do that tomorrow...
12-01-2017 1:19 PM
I have got the Update history thanks. This shows a goodly number of automatic items from 24/07/2016 but a smattering of updates either "Cancelled" or just "Failed" These were KB2876229, KB890830, KB3140345, KB3139923 all Cancelled (not by me) and KB3160005, KB3133923 (twice), KB2952664 Failed The latest Successful arrival dated19/10/2016 is KB3170106.
Nearly all the updates were graded Important with a few as Recommended. Is it possible to cherry-pick the ones that did not get installed? What do you think about the lack of anything since 19/10/2016?
Ultimately I intend to abandon Windows for Linux, probably Mint 18 Mate. Any ideas?
12-01-2017 1:51 PM
It's anyone's guess just how vulnerable your PC may (or may not) be given the missing updates - my advice would be to follow @Anonymous's and @ReedRichards advice on the first page of this thread to try to get them back on track.
No knowledge and hence no advice about Linux OS's.
12-01-2017 3:02 PM
After doing the "off line" install of KB3172605 .... as mentioned last week, the update for yesterday has now been downloaded and installed automatically on boot up.. took about 30 mins.. after re-boot, I check my "Update History"... and note that the December 2016 Monthly Quality Rollup kb31207752) FAILED...
However, the January 2017 Monthly Quality Rollup was success
@ReedRichards @Anonymous or anyone tell me if I need to now try to install that December Rollup, or does the next month ( in this case, January) Rollup, include the previous month, if not installed (due to prev failure)..
12-01-2017 3:22 PM
@shutter - If you mean KB3207752 mine shows as failed the first time, succeeded the second (both on 14/12/2016)
With mine set to check for updates but not download or install them until requested, I suppose I should remember re-requesting it, but I don't actually remember doing so (severe brain fatigue had set in by then I suspect!)
12-01-2017 3:24 PM
@shutter - I wouldn't have thought that this was needed as January's roll-up should include everything before it, as PCs are bought every day of the week this makes sense to me as it will cover those PC bought prior to the Jan roll up. I don't think you'll need to but...
... as this is MS we are dealing with can you not select this item, right click it and see if there is a retry option.
12-01-2017 3:31 PM
@Anonymous Logically thinking..... ( does microsoft do that ? ? ?) the Jan one should cover the December one..
As for the "right click" question... all that gives is View Details or Copy Details. ... which seems a bit "lax".. as to not having an option to "retry"..
12-01-2017 3:35 PM
@JayG yes, indeedy ! typo...
Three other updates on the same date/time were successful, but no second chance on that failed one...
12-01-2017 3:40 PM
@shutter - Well giving MS some credit I really don’t think you’ll need to apply the Dec roll-up as the installer (updater) should be smart enough to know that it was (is) a pre-requisite so attempt to re-install it or at least bleat about it.
Others may know different of course.
12-01-2017 4:33 PM
From past experience, it seems that MS add/replace the individual updates between "roll-up" issues and spend most of the update time trying to decide which elements have already been installed and don't need downloading again.
Phil
12-01-2017 11:13 PM
@shutter wrote:
...Logically thinking..... the Jan one should cover the December one..
I'm certain it does.
