Wifi device not showing as connected on wifi list, using Plusnet hub one. Cannot find ip address
Drifter
Hi
Help needed please.  I am now using a plusnet hub one due to my original one breaking down.
Have connected my laptop, ipads and mobile phone on the wifi but I cannot detect my Zgemma box.
The device is not showing up as connected.  Why is this not being detected please.
any help appreciated.
Regards
Phil
5 REPLIES 5
Mustrum
Fixes: 77
Re: Wifi device not showing as connected on wifi list, using Plusnet hub one. Cannot find ip addres
It seems to be a feature of the PN Hub.
However on the zgemma handset, press Blue/Network/Network Interface for yor IP address.
Drifter
OK, thank you will try that on the handset.
Drifter
Hi Mustrum
I know have my ip address for my Zgemma box.  I can see all channels on my TV but when I select one to play the screen goes black.  When I checked the following settings I see these details.
Mustrum
Fixes: 77
@Drifter Have you recently moved from Virgin?
Your DNS settings would appear to point to Virgin DNS numbers, which may be the cause of your problem.
Drifter
Hi
I have always been with Plusnet.
I am with Virgin for my mobile service.
Regards
Phil
