Wifi Link Speeds - Hub One
- Wifi Link Speeds - Hub One
06-12-2015 5:17 PM
Just thought id pose a question for the technical types
My Hub One arrived a couple of days back and I have set it all up with my preferred SSID and settings etc but the one niggle i have is my TP-Link WN722 USB wifi adaptor doesnt seem to be too keen on it! Its only Wifi-N 150mbps but when connecting to the Hub One it maxes its link at 65mbps?
Previously it would connect to the TalkTalk router at a steady 150mbps with no issues. My fibre is due to be installed on tuesday and Im not expecting much over 30mbps due to my line quality but 65mbs link is going to bottleneck me for sure.
Ive tried the obvious options, Ie making sure no B or G devices connected and also WPA2 only so its not throttled. Even sitting next to the Hub it still will not sync over 65. Tried inssider to look for channel congestion and its on the clearest channel in my area.
Ive managed to make a quick fix by bridging another old TT router (HG532) via Ethernet and i can link to that at 150mbps with no issues
Anyone have any further ideas or is it some sort of limitation with the Hub? Unfortunately the only other WiFi adapter to hand to test with is G so not much help c:)
Thanks in advance for any advice
Lee
Re: Wifi Link Speeds - Hub One
06-12-2015 6:55 PM
WiFi Alliance certified hardware is supposed to be configured to only use 20 MHz channel width by default on the 2.4 GHz frequency range. It's probably possible to configure the Hub One to allow 40 MHz channel width on the 2.4 GHz frequency band, although the useful speed you get from using 40 MHz won't necessarily be better than sticking to 20 MHz only, it will depend on what other networks and the devices in them it has to co-exist with.
07-12-2015 3:23 PM
Quote from: bales1983 My fibre is due to be installed on tuesday and Im not expecting much over 30mbps due to my line quality but 65mbs link is going to bottleneck me for sure.
if your wifi is going at 65meg and you expect a fixed wan side of 30meg your wan will be the bottleneck not the wifi .....
07-12-2015 5:36 PM
07-12-2015 6:14 PM
08-12-2015 4:34 PM
It was many years ago since I tested but IIRC on 54meg WiFI actual tcp throughput was more like 18.
That was with a clean channel, close and one user - once you start getting contention/collisions = packet loss it gets worse, especially as "normal" tcp expects a robust link layer and that any packet loss indicates congestion, so it backs off.
On that basis a 65meg WiFi could/will be the bottleneck.
08-12-2015 4:48 PM
your wifi will be able to send /receive at 30 each way the wan side will rate limit the wifi to match its throughput rate so instead of giving you 25/25 your going to get 30/2 on the adaptive rate
that's not to say you wouldn't benefit from a different wifi adaptor in the pc for stability reasons, but In the most basic terms the limiting factor will be the wan connection.
08-12-2015 7:37 PM
they can just manage 27Mbps down & 27Mbps up - but not simultaneously.
But 27+27=54Mbps
Obviously the title of the standard was written by marketing.
08-12-2015 7:40 PM
08-12-2015 8:45 PM
