Wifi Calling Dropping Out
- Wifi Calling Dropping Out
20-01-2019 2:18 PM
Afternoon,
Having moved to plusnet just last week I have been having problems with Wifi calling. I currently use Vodafone as my mobile operator.
Wifi calling was perfect when I had BT as my ISP but since I moved the wifi calling is very intermittent, sometimes its on and other times its not. The wifi is working. This is also happening to my wifes phone that uses BT as the mobile operator. So it is looking likely to be an ISP/Router problem.
I need it for work as I have no mobile coverage.
I was just wondering if anyone else has had this problem or where i might find help?
Regards
Andy
Re: Wifi Calling Dropping Out
20-01-2019 3:08 PM
Moderator's Note(s)
Thread moved from Broadband to Tech Help where it may be better served.
Forum Moderator and Customer
20-01-2019 3:51 PM
22-01-2019 1:47 PM
Yep, Thats what I have done and its all sorted now. Definitely the plusnet router.
