WiFi sign in
- Re: WiFi sign in
WiFi sign in
18-03-2020 9:46 AM
Re: WiFi sign in
18-03-2020 10:00 AM
Try switching the router off using the device on/off switch, not the mains. Leave it a minute and switch back on.
Re: WiFi sign in
18-03-2020 10:53 AM
Re: WiFi sign in
18-03-2020 2:45 PM
Plan B is to factory reset the Plusnet Hub by pushing a paperclip or similar in the reset hole. Keep the switch closed for 30 seconds. It will then take up to 15 minutes to set itself up again.
If that fails then forget the wireless connection on your device and then reconnect it.
Re: WiFi sign in
18-03-2020 4:08 PM
