WiFi keeps dropping out with Toshiba laptop and Vista
- WiFi keeps dropping out with Toshiba laptop and Vi...
15-12-2008 6:33 PM
Before I start spending money at a repair shop, can anyone suggest what else might be wrong ?
Re: WiFi keeps dropping out with Toshiba laptop and Vista
15-12-2008 11:28 PM
Have you got power options setup in Vista if so it could be going to sleep and dropping the connection.
Do all the other pc's stay connected when Vista drops the line?
When it drops does it re connect on its own and does it show a poor signal?
What encryption do you have set.
Is there any other networks near by on the same channel ?
does it drop when the other pc's are doing any heavy downloads transfers if the other pcs are struggling to get data and its resending to them a lot it may be to buzy to answer Vista
16-12-2008 9:14 AM
It may not fix your problem, but it will help your connection anyways.
16-12-2008 9:52 AM
1. Power options are not set up when the laptop is running on mains - that means, the laptop stays alive all the time. So I do not think it could be anything to do with that.
2. Yes, the other pc stays alive when the laptop drops the connection, but it is connected to the same router by ethernet. The other laptops (belonging to visitors) connected by WiFi all work without dropping the line (when they are here).
3. When the laptop drops, it will re-connect on its own if it can find the network. The signal is strong.
4. Encryption is WPA
5. There are other networks (neighbours) showing up but when my connection drops, they are usually no longer visible either. I have tried changing the channel to 9 but it makes no difference.
However, I Googled and found a recommendation to turn auto-tuning off, which I have done. ('netsh int tcp set global autotuninglevel=disable'). Is this a safe thing to do ?
I will also try turning off IPv6.
16-12-2008 12:10 PM
from what I have seen though, this is a verry common problem http://infopirate.org/wireless-drop-off-with-vista-basic for example has quite a lot of people with the same issue, as well as a couple of suggested solutions.
16-12-2008 5:35 PM
16-12-2008 5:57 PM
16-12-2008 6:02 PM
It does it on my laptop.
As a suffer of similar problems, I would be interested in advice as well.
16-12-2008 6:24 PM
A. Power settings
Check that when using the mains electricity, your Power Saving is set to Maximum Performance. If it is not, then the WiFi will turn itself off if it is not being used :
Click Start. Type Power Options in the Start Search box, and then click Power Options in the Programs list.
Click Change plan settings under the power plan that is selected. For example, if the Balanced option is selected, click Change plan settings under Balanced.
Click Change advanced power settings.
In the Power Options dialog box, expand Wireless Adapter Settings, and then expand Power Saving Mode.
In the list that appears, click Maximum Performance, and then click OK.
B. Enabling echo-ing from the router.
Open Windows Firewall with Advanced Security > Inbound Rules
Enable "File and Printer Sharing (ECHO Request - ICMPv6-In)".
C. If that does not work, then turn off IPv6 altogether.
Go to Network connections folder (can also be found by typing 'ncpa.cpl' into the Start menu search box). Then right click your network, select the networking tab and unclick Internet Protocol Version 6.
D. Check that you have the latest WiFi driver
Control Panel >Device Manager
Click on the "+" for Network adapters
Go to your wireless device
Right click, it should say "Update driver software..."
Click search automatically for updated software
E. Turning off the auto-tuning
Click on the Start menu and type 'cmd'.
Type CTR+SHIFT+ENTER to tell the command prompt to open with elevated privileges
In the command prompt window, type 'netsh int tcp set global autotuninglevel=disable' and hit Enter
F. Try changing the channel on the router to 11, 9 or 6 to avoid any conflicting hardware.
I hope some of those help. I am still experimenting but it does look hopeful.
I would appreciate any feedback on whether these work for anyone else.
16-12-2008 6:27 PM
Quote from: shermans
That might not find the latest driver, you are best going to the manufacturers website to see if there is a newer one.
