WiFi hotspots
briston
WiFi hotspots
Did I read somewhere or is it my imagination that PlusNet customers can access BT hotspots free?
1 REPLY 1
avatastic
Re: WiFi hotspots
You imagined it.
If you buy your own Fonera router and let others use your bandwidth then you can, but as an independent customer of Fon and then its only the BT-Wifi-Fon hotspots you can use.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
