WiFi hotspots
- WiFi hotspots
WiFi hotspots
18-02-2015 3:40 PM
Did I read somewhere or is it my imagination that PlusNet customers can access BT hotspots free?
1 REPLY 1
Re: WiFi hotspots
18-02-2015 4:43 PM
You imagined it.
If you buy your own Fonera router and let others use your bandwidth then you can, but as an independent customer of Fon and then its only the BT-Wifi-Fon hotspots you can use.
