WiFi goes down when landline rings
VMA
When my landline rings, my broadband connection drops out? Any idea why? I have a master socket that has the dsl and phone connection socket separate.
it’s never happened before, and started since an issue with my line.
3 REPLIES 3
Fixes: 387
Re: WiFi goes down when landline rings
If you have  an issue with the copper line/voice circuit, this is a perfectly normal problem.
Have you reported the line fault?
VMA
Yes I have, Is it worth me adding this as a note to the ticket?
Fixes: 387
Not really - if the line problem is resolved, the disconnections should cease.
