WiFi Internet Radio
- WiFi Internet Radio
WiFi Internet Radio
30-04-2010 10:50 PM
I'm considering getting a wifi internet radio, does anyone have any experience of them or any recommendations?
3 REPLIES 3
Re: WiFi Internet Radio
01-05-2010 6:05 PM
Yes, I have three Logitech Squeezeboxes around the house.
They will either:
a) connect to my library of MP3s on one of my computers (which needs to run Squeezebox Server and/or iTunes), or
b) (as I mainly use them) to listen driectly to Internet radio stations, without relying on any of my computers being on, by connecting them to mysqueezebox.com. In this case, you don't even need a computer, just a router!
The software is all free after you have the hardware, from the Logitech site.
They will either:
02-05-2010 8:14 AM
Thanks, can you use the BBC 'Listen Again' service with the Squeezebox?
03-05-2010 7:11 PM
Yes, certainly, if you use a local computer to run SqueezeBoxServer, then BBC iPlayer (radio) is available as a free plug-in download.
If you want to run Squeezebox(es) without a local server on your network, then you'd need to search the (very helpful) Squeezebox forums about that... I think it's been done, but it's certainly easier when using your own local computer as Squeezebox Server.
dick:quote
dick:quote
