WiFi Calling on EE mobilr
sueewing
Hi. I have just bought a new iPhone on EE that has Wifi Calling on it, which I was told would help overcome a poor signal at home. However, WiFi Calling can't be used in my house. The phone's been checked for faults and is ok.  Is this something to do with Plusnet? I know Plusnet Mobile doesn't support WiFi Calling but does PN's broadband service block it too?
3 REPLIES 3
bin
Re: WiFi Calling on EE mobilr
Shouldn't be a problem - I have wifi calling working with 3 no problem.
However, I do recall that you may need to actually be able to get a normal phone signal when you are first registering your phone with the wifi calling app. Once that's done it should be OK.
sueewing
Thanks for your reply.  I'll get back on to EE.
Fixes: 160
FWIW - I have an iPhone on EE and WiFi calling works fine over my Plusnet internet connection.
