Wi-Fi sniffer software -
- Re: Wi-Fi sniffer software -
08-12-2015 8:24 PM
Can someone recommend a good Wi-Fi- 802.11b/g/n sniffer program - for the PC with Windows - rather like the ones you get with Android phones.
I just want it to monitor channels around here
Mal
Mal
3 REPLIES 3
08-12-2015 9:14 PM
I used to use inSSIDer by metageek and found it ticked all the boxes for wifi channel info.
Unfortunately v4 is now trialware but, if you search online you may be able to find the previous freeware versions.
Have found this below but have not used it,so try at your own risk, although the interface seems too white for my liking.
http://lizardsystems.com/wi-fi-scanner
No problem can be solved from the same level of consciousness that created it.
Albert Einstein
Albert Einstein
08-12-2015 9:36 PM
Just done a google on " Download inSSIDer3 " and got directed to TECH SPOT site for inSSIDer 3.1.2.1
inSSIDer for Home gives you visibility into your Wi-Fi environment.
It gives 4 O.S. choices and it says " Windows Free" so choose that one...
(unless, of course, you have not got windows ! ! !)...
08-12-2015 10:03 PM
Many thanks - just what I was looking for
